disable ipmcforwarding tunnel
disable ipmcforwarding {tunnel tunnel_name}
Description
Disables IP multicast tunnel forwarding on a router interface.
Syntax Description
tunnel_name Specifies a tunnel name.
Default
Disabled.
Usage Guidelines
If no options are specified, all configured IP interfaces are affected. When new IP interfaces are added, IP multicast forwarding is disabled by default.
IP forwarding must be enabled before enabling IP multicast forwarding.
Disabling IP multicast forwarding disables any Layer 3 multicast routing for the streams coming to the interface.
The following example disables IP multicast forwarding on the tunnel called accounting:
disable ipmcforwarding tunnel accounting
This command was first available in ExtremeXOS 32.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
